This screwed our angle Bars. The weldment dimension given by the cultist is less or more to the dimension which is required. Did I make wrong when generating cultist? we already cut the bars only to find out that all was screwed. Can any one point me what is wrong
You still should be able to use group but I feel the issue is something different. I've a feeling that you're getting a combined length instead of individual length as you may be using the merge option. Can you attach your files to check/verify?
