Vertical or Horizontal linear dimensions, can the API get this? (drawing).
Question asked by Lars Ahlzen on Sep 27, 2018
Latest reply on Sep 27, 2018 by Lars Ahlzen
Hi
Well, it seems I have yet another problem that needs assistance. So I am trying to figure out how the API can know if a drawing dimension is vertical or horizontal.
Like the picture:
I have taken some advice from this API help script http://help.solidworks.com/2019/english/api/swdimxpertapi/get_dimxpert_display_dimensions_and_feature_example_vb.htm and this thread Horizontal or Vertical Dimension?
What I thought would work is this:
Dim DisplayDim As SldWorks.DisplayDimension
For i = LBound(vDimensions) To UBound(vDimensions)
     Set currDim = vDimensions(i)
     Set DisplayDim = currDim.GetSpecificAnnotation
     DimName = currDim.GetName
     Select Case (DisplayDim.Type2)
          Case swDimensionType_e.swLinearDimension
          Debug.Print DimName & "  Display dimension type = linear"
          Case swDimensionType_e.swHorLinearDimension
          Debug.Print DimName & "  Display dimension type = horizontal linear"
          Case swDimensionType_e.swVertLinearDimension
          Debug.Print DimName & "  Display dimension type = vertical linear"
     Case Else
          Debug.Print DimName & "  Display dimension type = unknown"
     End Select
Next
But even though I am intentionally putting in a vertical dimension and a horizontal dimension instead of using the smart dimension tool it returns as only linear. Maybe the drawing environment doesn't know if it is vertical or horizontal and just use linear all the time compared to the part environment that is more specific when it comes to linear dimensions. Maybe?
I have also tried to find the arrows positions to see if the x values of both the arrows are the same (then it is vertical) or the y values are the same (then it is horizontal). But I guess you can't get those coordinates... If anybody else has any smart solution to this I am all ears.
P.S If anybody has seen my previous posts I can tell you that I am still working on the same script and it is getting quite good wiyh the help I have gotten from the community, so thank you for that.
