2 Replies Latest reply on Sep 27, 2018 2:24 PM by Shuhei Kazuma
    How to get a count of Configurations in Part/Assembly?
    Shuhei Kazuma
      Dear experts,
      I would like to get the count of configurations given the Part or Assembly files. How can I do it? I use C# but any example is appreciated.
      Background:
      I want to write a code which modifies a global variable. But I need to use different methods depending on the number of configurations existing in the file.
      For example, if a part has multiple configurations, then I have to use
      swEqnMgr.SetEquationAndConfigurationOption(index, NewEquation, (int)swInConfigurationOpts_e.sw,null);
      However, for a part with a single configuration, then
      swEqnMgr.Equation[index] = NewEquation
      thank you in advance!
      SK
          • Re: How to get a count of Configurations in Part/Assembly?
            Shuhei Kazuma
            Thank you Anthony, that is what I was looking for. This seems to work well for now.
                    public static int FindEquationByName(ModelDoc2 swModel, string Name)
                        EquationMgr swEqnMgr = swModel.GetEquationMgr();
                        Regex pattern = new Regex(@"""(?<Name>\w+)""\s?=\s?(?<Equation>.*)");
                        for (int i=0; i<swEqnMgr.GetCount(); i++)
                            string eq = swEqnMgr.Equation[i];
                            Match match = pattern.Match(eq);
                            if (Name == match.Groups["Name"].Value)
                                return i;
                        return -1;
                    public static bool ChangeEquation(ModelDoc2 swModel, string Name, string Equation)
                        int ConfigCount = swModel.GetConfigurationCount();
                        int location = FindEquationByName(swModel, Name);
                        // if equation is found, change the value
                        if (location != -1)
                            string NewEquation = "\"" + Name + "\""+ " = " + Equation;
                            if (ConfigCount > 1)
                                Console.WriteLine("multiple config");
                                int result = swEqnMgr.SetEquationAndConfigurationOption(location, NewEquation, (int)swInConfigurationOpts_e.swAllConfiguration, null);
                                if (result == -1)
                                    return false;
                                else
                                    return true;
                            }else if(ConfigCount == 1)
                                swEqnMgr.Equation[location] = NewEquation;
                                return true;
                            else
                                return false;
                        return false;
