BTBob Tosi24/09/2018
Hi, I am doing a drawing to screen print some text and need to show locations. I am trying to dimension to the centers of numbers 4 & 7. I add sketch points to the model and showed them in the drawing. For some reason I can not select the points when adding dimensions. I then tried to add a point at the drawing level coincident to the point on the model, SW would not allow me to do that. The next thing I tried was to convert the sketch entities (line) but SW will not allow me to select the lines. I then just added points to the drawing and dimensioned then as needed. The problem with that is now I have points which cannot be hidden. Any ideas?
