Anybody knows if Solidworks 2019 will make it easier to switch computers using the same license? Reason I ask is because I run SW on two computers. My main computer is where I design the parts. I spend most of the time designing parts here. The second computer is where I run the CNC machine, and I only need SW to do touchups on details I missed. Rest assured this is required 101% of the times!
On the other license based tools that I have (i.e. Altium), you can grab the license by just going to the computer you want to use. The systems knows to disable the license on the computer where it is not being used. As it is, however, SW requires me to go to the computer where the license is, deactivate it, and then go to the other computer and activate it, and so on. Kind of a hassle which might be perfectly acceptable in 2005, but not as much on 2018. This would be a cool feature to have for sure!
Hi Jose,
Have you tried Online Licensing? It was released to the user base in 2018 SP2.0 and allows you to attach your license to a set of login credentials instead of manual activation/deactivation. You would then just login to whichever machine you wish to use at the time and the license would be moved there. This does require a consistent internet connection to these machines though.
If you are using version 2018 and a standalone license then your license already does this.
