Re: Trying to cut an elliptical ring between angled surfaces
Jeff Mowry Sep 25, 2018 7:34 PM (in response to Alissa Murphy)It's fairly simple, but I'd approach it with surfaces.
Loft an ellipse on the bottom of your needle that's 0.50 (units) offset from your inner edge to an ellipse on your ledge, as a surface feature. Then use the Cut with Surface feature to remove the part of the needle you don't want and this will form the taper you want.
Jeff Mowry Sep 25, 2018 7:42 PM (in response to Alissa Murphy)Attached is a quick sample file in v2017 format, for reference.
Sometimes you also have to build a sort of "end face" for your Cut with Surface feature to work properly.
Ellipses get weird when you offset them inward (like I did with this model), but it should be enough to show how to perform the cut you need.
Elliptical-Surf-Cut.SLDPRT.zip 173.9 KB
Alissa Murphy Sep 28, 2018 12:32 PM (in response to Jeff Mowry)Thanks so much! This seems like the right approach. Can you say a bit more about building an "end face" for the cut? I've created the loft but I'm getting the error "operation failed due to geometric condition" when I try to cut with surface. It doesn't seem like I can add more than one parameter during the cut step.
Many thanks,
Alissa
Paul Salvador Sep 28, 2018 12:58 PM (in response to Alissa Murphy)Alissa,.. try Replace Face.
Alissa Murphy Sep 28, 2018 1:03 PM (in response to Alissa Murphy)Thank you Paul and Jeff! The combination of the lofted surface and "replace face" worked!
Best,
Alissa
Alissa Murphy Sep 28, 2018 1:39 PM (in response to Alissa Murphy)Actually... back to the drawing board. I need to cut new features in that surface, and it seems I can't- the new surface remains even through a cut. That doesn't seem to be true for the "cut with surface" feature (I tested it on Jeff's part). So I'm still happy to hear any advice about how to make that feature work by including an end face (or other possibilities).
Thanks!
Paul Salvador Sep 28, 2018 1:44 PM (in response to Alissa Murphy)Alissa,.. it may be bcuz the loft surface used in the replace face is visible,.. so, you would need to hide it or delete it.
Alissa Murphy Sep 28, 2018 5:39 PM (in response to Paul Salvador)Got it! Thanks!
John Stoltzfus Sep 28, 2018 12:35 PM (in response to Alissa Murphy)Did you try the chamfer tool?
