How to apply tangent relation to constrain the sketched spline.
Tangent relation between surface spline and sketched spline. Tangent symbol should display in sketch as well as the surface.
Can anyone help me on this.
Hi Anand,
it's difficult to see what you are trying to achieve. but in any instance, it appears your spline ends do not connect to any feature that would help define them, ie a tnagent edge or another sketch entity.
Assuming you're trying to connect the straight face to the round one, it would be worth defining the edges of both by either trimming them or adding split lines. Also assuming the spline doesn't need to be a 3D spline, if you insert a plane, or extrude a surface to act as a sketch plane, you could them easily add a spline between the two defined edges.
Hi Anand J.,
Are you able to attach the model here so that forum members can have a proper look?
Dave.
Hi Anand,
have you got 'enable spline tangency and curvature handles' checked in system options?
