Hey people of SolidWorks!
I am coding an Add-In for SolidWorks and I'm trying to get the feature properties of the design tables.
When I am using the ConfigurationManager I just get the stuff listed below the Configuration section: "Standard" and "help[...]"
Then I tried the DesignTable interface. With the GetTitle() method I just get the title inside of the excel sheet..
And actually I thought that DesignTable.FileName should do it, but it is always returning me an empty string.
I created a SWDesignTable class to store all the informations. Here is a little code snippet in C#:
doc = Connector.ActiveDocument;
var config = new SWDesignTable(doc);
var designTable = (DesignTable)config.ExcelTable;
string designTableName = designTable.FileName;
ouput: designTableName = ""
So do you guys know, how I can get access to the feature properties of the design table for getting informations like name, description, created by and so?
If you need more information, don't hesitate to ask!
