CloseAllDocuments but NOT the active model
Question asked by Niels Raahauge on Sep 20, 2018
Latest reply on Sep 20, 2018 by Niels Raahauge
Sometimes a SWA open a lot of parts. I would like to close them by a macro.
If the SWA is edit, I can use  boolstatus = swApp.CloseAllDocuments(False)
The active document stay open as wanted.
I would like to close all but not the active SWA - without edit it.
I have tried to add a props in the active model, and delete it again after close all - but i does not work.
If I change add the props outside the macro - it is detected as a changes - and it stays open after close All.
It seems that solidworks not detect a props change as a change in the document - the document can be closed without prompt for save if this command are used:
AddStatus = CustPropMgr.Add3("TempProps", swCustomInfoText, " ", 0)
'open some documents
'add temp props
'close all -not edit- documents
'delete the temp props
'Does not work, because a props change - are not detected as a document change
Option Explicit
Dim swApp As SldWorks.SldWorks    ' Define variable used to hold the SldWorks object
Dim swModel As SldWorks.ModelDoc2 ' Define variable used to hold the ModelDoc object
Dim boolstatus As Boolean
Dim result As Integer
Dim swCustPropMgr As SldWorks.CustomPropertyManager
Set swModel = swApp.ActiveDoc ' Grab the currently active document
'make a document edit-to keep document open
Dim CustPropMgr As SldWorks.ICustomPropertyManager
Set CustPropMgr = swModel.Extension.CustomPropertyManager("")
Dim AddStatus As Long
result = MsgBox("Close all documents that have no changes?", vbYesNo, "Solidworks")
Select Case result
Case vbYes
    ' If false, then all documents, excluding any dirty documents, are closed
    Debug.Print "All documents, excluding dirty documents, closed: " & boolstatus
    ' If true, then all documents, including any dirty documents, are closed
    'boolstatus = swApp.CloseAllDocuments(True)
    'Debug.Print "All documents, including dirty documents, closed: " & boolstatus
Case vbNo
    'End
End Select
Set swCustPropMgr = swModel.Extension.CustomPropertyManager(Empty)
swCustPropMgr.Delete "TempProps"
