It is possible to hide all of the user interface elements, including the SolidWorks menu bar?
Could you please clarify why do you want to do this?
There is no direct API for doing this
I see several options:
Artem Taturevych, I just stumbled across this post and your answer. I have been asked to create an application where SOLIDWORKS is going to run in a small low resolution screen at a production machine. SOLIDWORKS will be controlled by a small configurator application and the user does not to be able to work manually with SOLIDWORKS. So in order to reduce complexity for the user and also in order to optimize space at the small screen we would like to run SW with all menus hidden - with only the graphical window visible.
Can you elaborate a little more about how to use Windows API to hide menus in SOLIDWORKS - push me in the right direction - maybe with a link to an example showing a principle solution for how to do it. Thank you :-).
