My company recently acquired a Stepoko CNC Machine from Sparkfun. We are looking to utilize SolidWorks new CAM feature with the machine for some in-house prototyping. The Stepoko board runs on Grbl v1.1, so I need a post-processor that will output to a format like that. None of the standard machine profiles included with SolidWorks seem to work. I've downloaded and tried to run this post-processor someone developed for just this kind of process, but I still have errors. The G-Code continues to write G41 commands which are not accepted with GRBL for whatever reason. That's not the only issue I have, but it's the main one.
Any suggestions on how to get things up and running?
Steven,
If your machine does not like the Cutter compensation, you can turn it off in the contour mill operations. If you find that it runs after turning off the setting below, I would change the settings and then use "Save Operation Plan" to overwrite the settings in the techdb so you do not have to change it every time. Please post out a short test with this option turned off. It should remove the cutter compensation or G40,G41 commands.
Mike
