JMJerome Maiere19/09/2018
I can import properly a STL file manually with SW2018 as a Solid or Surface or Graphics (using Options/Import/STLFiles), but when I use a macro to open the same STL file, I only get a Mesh result (without errors) rather than a Solid or Surface for instance.
I tried many things including changing swImportStlVrmlModelType to 2 for Solid, but the result is always a Mesh.
Once again, everything works well when importing manually.
Anyone have an idea of the problem with the macro? Thanks.
Here is my macro:
Option Explicit
    Dim retVal As Boolean
    Dim ImportStlVrmlModelType As Long
    Dim ImportStlVrmlUnits As Long
    Dim Err As Long
    Dim Errors As Long
     Dim stlFileName As String
   ImportStlVrmlModelType = swApp.GetUserPreferenceIntegerValue(swImportStlVrmlModelType)
    swApp.SetUserPreferenceIntegerValue swImportStlVrmlModelType, 2  '0 = Graphics body . 1 = Surface,  2 = Solid
    swApp.SetUserPreferenceIntegerValue swImportStlVrmlUnits, swMETER
' just in case, I tried to enable/disable  the 3dInterconnect but it doesn't help
  swApp.SetUserPreferenceToggle swUserPreferenceToggle_e.swMultiCAD_Enable3DInterconnect, False
     stlFileName = "XXX.stl"
     retVal = swApp.LoadFile2(stlFileName, "r")
    Debug.Print ("Error (0 = no error): " & Err)
