I am trying to create deformed "lamellas" in a (sheet metal) plate.
They are basically laser cut all around except from a very small part at the top of both
sides of every lamella. After this they are bended. Because there is only a very small
piece of metal left the complete lamella bends 90°. I can't figure out how to create
this in Solidworks. So far I have found it is not possible to use a normal flange or tab because
there is no material left to use this.
Please see the attached picture for further clarification.
We are using Solidworks 2014.
I would really appreciate it if someone could help me out?
Paul Vruggink
I played around with this one for you and I think that this part will give you the basics enough for you to draw to your design. If you want a one line laser cut, you will need to modify the dxf flat pattern that this creates.
