Solidworks 2016 Open PDM Files for Property Update?
Question asked by Paul Ambler on Sep 18, 2018
Latest reply on Sep 26, 2018 by Paul Ambler
I'm fairly well versed at VBA with MSAccess but not with Solidworks. Our company has standard PDM. I need to create a macro I can run with Task Scheduler that will open all files in a specific folder (code attached shows just one file as I am starting small) one by one, check the custom properties, check out the file if necessary, update the custom properties, then check the file out. I have thousands of files to run this on. I have already checked the properties update code and it works fine if you already have a model/assembly open. I need to make it work when the model/assembly is not open now.
I'm hitting a wall. Here's my code:
Dim swDoc As ModelDoc2
'Dim files As Variant
Dim files As String
Dim folder As String
Dim fileerror As Long
Dim filewarning As Long
Dim part As Object
Dim model As SldWorks.ModelDoc2
folder = "C:\JanisVault\2-Top Level Assembly Drawings & Non-Inventory\Solid Parts\56000-56999\"
files = folder & "56672.sldprt"
Dim cpm2 As CustomPropertyManager
Dim cpm3 As CustomPropertyManager
Dim names2() As String
Dim names3() As String
Dim copy1config As String
Dim copy2config As String
Dim confignami As String
Dim confignamj As String
Dim configvali As String
Dim configvalj As String
Dim i As Integer
Dim j As Integer
Dim NewPropOk As Boolean
Dim NumProps As Long
Dim NumProps2 As Long
Dim swDocPART As Long
Dim Propname As Variant
Dim Proptype As Variant
Dim Propvalue As Variant
Dim Propname1 As Variant
Dim Proptype1 As Variant
Dim Propvalue1 As Variant
Dim longstatus As Long
Dim longwarnings As Long
copy1config = ""
copy2config = "Default"
Set part = swApp.OpenDoc6(files, swDocPART, swOpenDocOptions_Silent, "", fileerror, filewarning)
swApp.SetCurrentWorkingDirectory (folder)
Set part = swApp.ActivateDoc3(files, True, fileerror, filewarning)
Set model = swApp.ActiveDoc
If model Is Nothing Then
    MsgBox "There is no active Document"                     ' <--- Currently shows this msgbox
Set cpm3 = model.Extension.CustomPropertyManager(copy1config)               '<--- This is where it stops with Run-time Error 91
If IsEmpty(cpm3.GetNames) Then
    'Continue
Else
    names3 = cpm3.GetNames
    NumProps = cpm3.GetAll(Propname, Proptype, Propvalue)
    For j = 0 To UBound(names3)
    configvalj = Propvalue(j)
    confignamj = Propname(j)
    Set cpm2 = model.Extension.CustomPropertyManager(copy2config)
    If IsEmpty(cpm2.GetNames) Then
        GoTo 30
        Else
        names2 = cpm2.GetNames
        NumProps2 = cpm2.GetAll(Propname1, Proptype1, Propvalue1)
        For i = 0 To UBound(names2)
        configvali = Propvalue1(i)
        confignami = Propname1(i)
        If confignami = confignamj Then
            If configvali <> configvalj Then
                If IsNull(configvalj) Or configvalj = "0" Then
                    GoTo 20
                    Else
                    If IsNull(configvali) Or configvali = "0" Then
                        If model.IsLocked = False Then
                            model.LockFile folder, 0, 0
                        model.DeleteCustomInfo2 copy2config, confignami
                        NewPropOk = model.AddCustomInfo3(copy2config, Propname(j), Proptype(j), Propvalue(j))
                        model.LockFile folder, 0, 1
                        GoTo 20
                Else
                GoTo 20
10
        Next
30
20
    Next
End
