Set variable for PDM template files in API?
Question asked by David Watkins on Sep 18, 2018
I have C# code that will run the PDM template file but our template requires the order # input to make the correct folders structure and file names. What I can't find is if there is a way to pass in a variable when running the template? I would like to do it as part of RunEx so there is not user inputs. Any ideas?
mostly from http://help.solidworks.com/2017/english/api/epdmapi/Execute_Template_Example_CSharp.htm2017 SOLIDWORKS API Help - Execute Template Example (C#)
            //Access template in the selected vault
            IEdmTemplateMgr5 templateMgr = default(IEdmTemplateMgr5);
            templateMgr = (IEdmTemplateMgr5)vaultTest.CreateUtility(EdmUtility.EdmUtil_TemplateMgr);
            IEdmPos5 pos = default(IEdmPos5);
            pos = templateMgr.GetFirstTemplatePosition();
            IEdmTemplate53 template = null;
            while (!pos.IsNull)
                template = (IEdmTemplate53)templateMgr.GetNextTemplate(pos);
                string message = template.GetMenuString();
                if (message.Contains("IPN"))
                    EdmRefreshFlag refreshFlag = default(EdmRefreshFlag);
                    object[] retData = null;
                    refreshFlag = (EdmRefreshFlag)template.RunEx(0, vaultTest.RootFolderID, out retData);
