Is there a way to have a transition that prompts for a user input to set a variable? Often, files in our vault get transitioned when they shouldn't be, so the vault revision doesn't match the drawing revision. Currently, our workflow is set up so that we can manually transition a file to specific revision. But each revision is set up as it's own transition, so our workflow looks very cluttered. I would like to be able to have a transition that will ask me for the revision, and set it to that, so I would only have to have one instead of over 20. Is this possible?
I believe you could set that up with dispatch. (we don't have it turned on here, so I can't test).
2018 SOLIDWORKS PDM Help - Dispatch (For SOLIDWORKS PDM Professional only)
there is also a recently added command to "set revision" that may help you out as well.
2018 SOLIDWORKS PDM Help - Set Revision Dialog Box
