I would like to loft the airofoil profile to a point using two guide curves to generate a delta wing. I have created 4 sketches for this. On the front plane is the airfoil profile, on the top plane is one guide curve going 65deg backwards starting from the airfoil nose, then a second guide curve on the top surface going perpendicular to the profile starting from its end point, and a third sketch on the top plane being a point where both guide curves intersect.
When I try to use the loft feature SW is unable to loft. I have tried lofting with and without guide curves without success. Any advice please?
First thing I would do is attempt to Extrude the Profile sketch to test the sketch.
What happens if you break up Curve1 into two separate curves?
