In our company we use file name as PN in BOM and Description as a custom property.
We need for some components to have the two values defined in the Configuration properties and it does not work.
I tested on my computer and also on a computer with a new SW installation- same results.
Has any of you experienced this and found solution?
Here is the sequence:
- Create a part
- Set Cfg properties to use Cfg name as PN and Description in BOM:
- Save and insert the part in an assembly
- Save assembly, make a drawing and insert BOM. and here is what I get:
If I go back to the part, open Cfg properties, click OK and then Ctrl+Q and Save then the drawing BOM shows correct fields:
Just to clarify- we are at SW2018 SP3
Message was edited by: Anthony Kanov
I was able to duplicate your issue. Seems like a bug to me. Have you contacted your VAR?
