This is a MySolidWork tutorial. How to use Tooling Split for this part? It does not work as guided in the tutorial. Also I used surface knit and tried but it did not work as well.
Pdf page# 14
Pdf page# 14
I'm digging through the part you attached...you failed to follow the tutorial.
For the "Parting Line 1" feature, you did not select the face that the tutorial was telling you to select.
You selected the planer face in the bottom of the dustpan...
The face you selected is not the same face that was shown being selected in the tutorial...
Then, for "Parting Surface 1", you select the wrong surface yet again...
The face you finally selected for "Plane 5", is the face you were also supposed to have selected for the other 2 features...
The error message says exactly what your problem is...
"Input sketch plane direction & pull plane are not parallel"
The face that you selected for the first one, is the face Solidworks used for the second one...making both of them wrong. The second one is a "ripple effect" error...it automatically used the face you had selected in the first one. Because you selected the wrong face in the first one, the wrong face was used by Solidworks for the second one.
I would suggest you to start over and follow the tutorials as instructed
As Doug Seibel pointed above, your parting line face selection is wrong and the parting surface is not perpendicular to the sketch plane
The "Parting line 1" feature isn't able have the pull plane face changed. You can edit it and select a different planer face and click on the green check-mark...but when you edit it again to make sure it took the change you discover that it didn't. You will have to delete it and do it over.
