IEIsaiah Engle15/09/2018
I am trying to connect some 3d printed components without the use of glue, adhesive, or snap fit joints. I want to use a quarter turn that will lock the two pieces together. I have a cylinder and am trying to create a cut out path on the inside of the cylinder to have a path for the other joint to connect to. I am attaching an image of the cylinder. I want to create a cut where the blue marking shows. How do I go about this? I tried using the revolved cut but am unable to select an access of rotation to cut around.
