Is it possible to know if a part is virtual reading the document through document manager API?
I am using GetDocument to get the part file and then GetComponents, so I can then look isVirtual property on the component.
The problem is for the virtual part is returning None so I can go on checking if its virtual
swDocPart = (SwDMDocument19)mDocumenManager.GetDocument(path, nDocType, true, out nRetVal); => RETURNED NONE
if (nRetVal != SwDmDocumentOpenError.swDmDocumentOpenErrorNone)
// if it can't find the file
if (nRetVal == SwDmDocumentOpenError.swDmDocumentOpenErrorFileNotFound)
// look if its virtual
SwDMConfiguration12 config;
SwDMConfigurationMgr configMgr = swDocPart.ConfigurationManager;
config = (SwDMConfiguration12)configMgr.GetConfigurationByName(configMgr.GetActiveConfigurationName());
object comps = config.GetComponents();
Array arrComps = (Array)comps;
foreach (SwDMComponent9 swComp in arrComps)
bool isVirtual = swComp.IsVirtual;
