I met something strange in the standard eye nut DIN582 - feature without feature
if you've had a look at the loft feature, you will find the reason.
The profiles are not selected at the corresponding point. So a self-crossed body is the (wrong/unwanted) result.
Pull the green point towards the inner point and you will see - everything is fine then.
Cheers, Heiko
Oh! It`s so simple, it is toolbox part and I`m not sure that it`s wrong. I`ve created my own without this neck.
If you choose a bigger size, you will find the neck growing … this could not be right!
Cheers, Heiko
