0 Replies Latest reply on Sep 13, 2018 7:07 AM by Adam Chapman
    How to pull a radius of a 2D sketch and put this in to an excel document relating to the center point of rad?
    Adam Chapman
      I have a macro to pull points of a 2D sketch. But its pulling through center points for the radius. I am wanting the macro to either remove the center points of the radius or pull through the radius relating to the center point. The reason i am doing this is to get X and Z to make it easier programming a CNC Lathe. Any help would be appreciated.
      Macro Shown Below
      Dim swApp As Object
      Dim doc As SldWorks.ModelDoc2
      Dim part As SldWorks.PartDoc
      Dim sm As SldWorks.SelectionMgr
      Dim feat As SldWorks.Feature
      Dim sketch As SldWorks.sketch
      Dim vp As Variant
      Dim ip As Long
      Dim sseg As SldWorks.SketchSegment
      Dim sline As SldWorks.SketchLine
      Dim sp As SldWorks.SketchPoint
      Dim s As String
      Dim exApp As Object
      Dim sheet As Object
      Set exApp = CreateObject("Excel.Application")
      If Not exApp Is Nothing Then
        exApp.Visible = True
         exApp.Workbooks.Add
         Set sheet = exApp.ActiveSheet
         If Not sheet Is Nothing Then
          sheet.Cells(1, 2).Value = "X"
          sheet.Cells(1, 3).Value = "Z"
          sheet.Cells(1, 4).Value = "R"
      Set swApp = GetObject(, "sldworks.application")
      If Not swApp Is Nothing Then
        Set doc = swApp.ActiveDoc
        If Not doc Is Nothing Then
         If doc.GetType = swDocPART Then
          Set part = doc
          Set sm = doc.SelectionManager
          If Not part Is Nothing And Not sm Is Nothing Then
           If sm.GetSelectedObjectType2(1) = swSelSKETCHES Then
            Set feat = sm.GetSelectedObject4(1)
            Set sketch = feat.GetSpecificFeature
            If Not sketch Is Nothing Then
             vp = sketch.GetSketchPoints
             For ip = LBound(vp) To UBound(vp)
              Set sp = vp(ip)
              If Not sp Is Nothing And Not sheet Is Nothing And Not exApp Is Nothing Then
               sheet.Cells(2 + ip, 2).Value = Round(sp.X * 1000, 3)
               sheet.Cells(2 + ip, 3).Value = Round(sp.Y * 1000, 3)
               exApp.Columns.AutoFit
             Next ip
