Hi Guys,
Is there a possible to link sheet name to page No.? Now I fill it by hand. Is sheet name can be automatically change like page when you change the sequence? Thanks.
Hi Guys,
Hi Manish, Thank you for your reply. Just the opposite, I want the sheet name can follow the page number. Once the page sequence is changed, the sheet name can follow automatically. I tried , maybe it's not possible.
It is directly not possible but you can do it via macro. You can also use the rename sheet tool from #TASK (a free program for SOLIDWORKS with lots of inbuilt tools)
Richard Yan - The easiest way is to use the attached Macro - You may need to edit the placement location in the macro... This macro will rename the sheets and will allow you to have cover sheets.
