Macro to update revision table
Question asked by Kenneth Coutinho on Sep 11, 2018
Latest reply on Sep 17, 2018 by Kenneth Coutinho
Hey guys,
I was trying to create a macro to populate the revision table.
This is sort of how my revision table looks like:
REV.
DESCRIPTION
DATE WITH INITIALS
APPROVALS
AECR 8000029279: RELEASE TO PROD AS PER EAO 60531.29JUN18 KCNJ/VS
BECR 8000029920: ADDED NOTE 3.221.10SEP18 KCYS/VS
  • The revision are alphabetically incremented but we can't use I, O, Q, S, X & Z (for obvious reasons)
  • The ECR no. strictly has to be 10 digits only
  • If there is an EAO no. (strictly 5 digits) then it has to be preceded by "RELEASE TO PROD AS PER EAO"
  • If there isn't an EAO no. then the description of the change need to be added.
  • The date is followed by the drafter initials
  • Initials of the engineers who will approve the drawing need to be added.
  • The 2nd row is deleted if the number of rows is greater than 5.
I have tried to write the macro but get stuck at the following line:
myTable.Text(3, 0) = ""
Please help me complete the macro.
Dim swApp As Object
Dim Part As Object
Dim boolstatus As Boolean
Set Part = swApp.ActiveDoc
boolstatus = Part.Extension.SelectByID2("DetailItem317@Sheet1", "REVISIONTABLE", 0.458763552490702, 0.391996361444788, 0, False, 0, Nothing, 0)
Dim currentSheet As Object
Dim myRevisionTable As Object
Set currentSheet = Part.GetCurrentSheet()
Set myRevisionTable = currentSheet.RevisionTable
longstatus = myRevisionTable.AddRevision("")
Dim revEcr As String
Dim revDrafters As String
Dim revInitials As String
nowtext = UCase(Format(Now(), "DDMMMYY"))
revEcr = InputBox("Enter ECR No.:")
revDrafters = InputBox("Enter your initials:")
revInitials = InputBox("Enter ME/RF initials:")
Dim myNote As Object
Dim myAnnotation As Object
Dim myTextFormat As Object
Set myNote = Part.InsertRevisionSymbol(0.433624764657207, 0.353991264877615)
If Not myNote Is Nothing Then
   myNote.LockPosition = False
   myNote.Angle = 0
   boolstatus = myNote.SetBalloon(1, 0)
   Set myAnnotation = myNote.GetAnnotation()
   If Not myAnnotation Is Nothing Then
      longstatus = myAnnotation.SetLeader3(swLeaderStyle_e.swNO_LEADER, 0, True, False, False, False)
      Set myTextFormat = Part.GetUserPreferenceTextFormat(0)
      myTextFormat.Italic = False
      myTextFormat.Underline = False
      myTextFormat.Strikeout = False
      myTextFormat.Bold = False
      myTextFormat.Escapement = 0
      myTextFormat.LineSpacing = 0.001
      myTextFormat.CharHeight = 0.0035
      myTextFormat.TypeFaceName = "Arial Narrow"
      myTextFormat.WidthFactor = 1
      myTextFormat.ObliqueAngle = 0
      myTextFormat.LineLength = 0
      myTextFormat.Vertical = False
      myTextFormat.BackWards = False
      myTextFormat.UpsideDown = False
      myTextFormat.CharSpacingFactor = 1
      boolstatus = myAnnotation.SetTextFormat(0, False, myTextFormat)
Part.ClearSelection2 True
Part.WindowRedraw
boolstatus = Part.Extension.SelectByID2("DetailItem317@Sheet1", "REVISIONTABLE", 0.463316246350311, 0.391006645388351, 0, False, 0, Nothing, 0)
Dim myTable As Object
Set myTable = Part.SelectionManager.GetSelectedObject5(1)
boolstatus = Part.Extension.SelectByID2("DetailItem317@Sheet1", "REVISIONTABLE", 0.478161987196863, 0.388631326852903, 0, False, 0, Nothing, 0)
myTable.Text(3, 1) = "ECR & revEcr: REL TO PROD AS PER EAO XXXXX"
boolstatus = Part.Extension.SelectByID2("DetailItem317@Sheet1", "REVISIONTABLE", 0.555557782810221, 0.392986077501225, 0, False, 0, Nothing, 0)
boolstatus = Part.Extension.SelectByID2("DetailItem317@Sheet1", "REVISIONTABLE", 0.553578350697347, 0.391006645388351, 0, False, 0, Nothing, 0)
myTable.Text(3, 2) = "nowtext & revDrafters"
boolstatus = Part.Extension.SelectByID2("DetailItem317@Sheet1", "REVISIONTABLE", 0.570997353290635, 0.391006645388351, 0, False, 0, Nothing, 0)
boolstatus = Part.Extension.SelectByID2("DetailItem317@Sheet1", "REVISIONTABLE", 0.571195296501922, 0.391006645388351, 0, False, 0, Nothing, 0)
myTable.Text(3, 3) = "revInitials"
