Macro to position model and render with PV360
Question asked by Tim Bethlehem on Sep 10, 2018
Latest reply on Sep 12, 2018 by Tim Bethlehem
I'm trying to make a macro for rendering models (assembly files, SolidWorks 2018, VBA macro).
The render itself is working fine, using RayTraceRenderer.
Positioning using the ShowNamedView2 function also works as expected.
To get a nice position of the model though, I want to move it a bit more. Untill now we've been doing it like this:
Select front view (ctrl+1), hit the left arrowkey 3 times and hit the down arrow key.
I'm able to get the right position using the VBA macro, as long as the render isn't invoked. As soon as I add the line to initiate the render the keystrokes (arrow keys) are executed after the render is done. Looks like I've built a time machine
Here's my code:
Option Explicit
Dim status As Boolean
Declare PtrSafe Sub Sleep Lib "kernel32" (ByVal dwMilliseconds As LongPtr)
Declare PtrSafe Sub keybd_event Lib "user32.dll" (ByVal bVk As Byte, ByVal bScan As Byte, ByVal dwFlags As Long, ByVal dwExtraInfo As Long)
Dim swRayTraceRenderer As SldWorks.RayTraceRenderer
Dim swRayTraceRenderOptions As SldWorks.RayTraceRendererOptions
    Const VK_UP = &H26
    Const VK_LEFT = &H25
    Const VK_DOWN = &H28
    Set swModel = swApp.ActiveDoc
    swApp.RunCommand swCommands_e.swCommands_Hideshow_Brwser_Tree, ""
    swModel.ShowNamedView2 "*Front", -1
    keybd_event VK_LEFT, 0, 0, 0
    keybd_event VK_DOWN, 0, 0, 0
    swModel.ActiveView.AddPerspective
    swModel.ViewZoomtofit2
    Set swRayTraceRenderer = swApp.GetRayTraceRenderer(swPhotoView)
    Set swRayTraceRenderOptions = swRayTraceRenderer.RayTraceRendererOptions
    status = swRayTraceRenderer.DisplayPreviewWindow
    status = swRayTraceRenderer.RenderToFile("c:\temp\Filter_2", 0, 0)
    swModel.ActiveView.RemovePerspective
    status = swRayTraceRenderer.CloseRayTraceRender
I've tried adding Sleep to give the script some time to execute the keypresses, but that makes no difference.
First I tried it with SendKeys, but as it's kinda iffy I prefer this keybd_event-function.
When I don't run the RenderToFile function it's all fine. But as soon as the Render-function is called the keystrokes are executed at the end of the script.
I'm at a lost here. Any ideas?
