i'm trying to mirror a part in SW 2018 But in can figured out
Updated
Updated
Insert > Mirror Part... should do what you want, assuming you want to create a new Part file. If you don't have a plane pre-selected it will be grayed out, so be sure you pick a plane first.
If you only want a second body within the same Part file, then you can use the Mirror feature, as Tony Tieuli said. "Features to Mirror" will be selected by default. You'll need to de-select it, then choose "Bodies to Mirror" instead before selecting the body to mirror.
