Dear All,
Now i have created a numbering system where it creates a drawing number using different inputs.
Now each inputs is controlled by a variable and that variable is controlled by a list.
Now for a given input if I select a different name from the list. I dont want it create a serial number/ or dont generate that serial number.
For example , If i select the following input above it will generate the number,
APAO00063
But let say in machining type if I went for Secondary instead of Primary, then serial number shall not increment!
How can we achieve this?
It is my understanding that this is a limitation of PDM/SQL. PDM cannot look at one variable and decided how a serial number issued in another variable behaves.
I can think of two options here:
