4 Replies Latest reply on Sep 10, 2018 2:03 AM by ZhongYu Hao
    How to cerat a part from API
    ZhongYu Hao
      Hello guys,
      I just started learning SW API
      And how to creat a New part ,assembly and drawing ,use API.
      That is my code,but it is still not work.
      Imports SolidWorks.Interop.sldworks
      Imports System
      Public Class Form1
          Private swApp As Object
          Private swDocumentTypes_e As Object
          Private swOpenDocOptions_e As Object
          Sub Main()
              Dim swApp As SolidWorks.Interop.sldworks.SldWorks
              swApp = New SolidWorks.Interop.sldworks.SldWorks()
              swApp.ExitApp()
              swApp = Nothing
          Private Sub Button1_Click(sender As Object, e As EventArgs) Handles Button1.Click
              Dim swModel As ModelDoc2
              Dim swPart As PartDoc
              Dim swBody As Body2
              Dim nPt() As Double
              Dim vPt As Object
              Dim bRet As Boolean
              swModel = swApp.NewDocument("C:\ProgramData\SOLIDWORKS\SOLIDWORKS 2015\templates\part.prtdot", 0, 0, 0)
              swPart = swModel
              swBody = swPart.CreateNewBody
      End Class
        • Re: How to cerat a part from API
          Deepak Gupta
          Check and make sure that your part template path is correct. If not then change this path "C:\ProgramData\SolidWorks\SolidWorks 2015\templates\Part.prtdot" to correct location/path.
            ZhongYu Hao
            I change this path is correct.but VS show me an error.
                Mr Omkar Deshpande
                Try
                Imports System
                Public Class Form1
                    Dim swApp As SldWorks
                    Sub Main()
                        'Dim swApp As SolidWorks.Interop.sldworks.SldWorks
                        'swApp = New SolidWorks.Interop.sldworks.SldWorks()
                        'swApp.ExitApp()
                        'swApp = Nothing
                        Dim swBody As Body2
                        Dim nPt() As Double
                        Dim vPt As Object
                        Dim bRet As Boolean
                        swPart = swModel
                    Private Sub Form1_Load(sender As Object, e As EventArgs) Handles MyBase.Load
                        swApp.Visible = True
                End Class
                Also, check your path of template
                    ZhongYu Hao
                    Thank you very much!!
                    That is Correct Answer!!!
                    I lost this
