I’d suggest setting it up and use the manufacturers fan curve.
I‘m assuming this fan is just part of a system you are modelling and you are not just modelling the fan alone.
If you try to model the fan impeller you will need a huge model to resolve it correctly, you would be better modelling the inlet and outlet geometry and then use the fan curve.
Good luck
Peter
