I´ve done a 3D routing and my diagram is done including drawings. Also, the Circuit summary appeared with the length of wires as usual. The problem came up where I generate the list of wires in the Schematic in Solidworks Electrical the length shows 0 in all the time.
Does somebody knows how to make them synchronize?
Thanks in advance.
Are you looking at the reports in your drawing tab or looking at the report previews under project>reports? If you are looking at the generated drawings, you'll need to right click on them and click "update...". If you are looking at the report preview in the Project>Reports tab, then reach out to your VAR, this should definitely be updating the lengths.
