I was sent this model from a pattern shop and the customer has requested that it be changed into a solid model. My problem is there are faces that exturde through the walls that I can't seem to trim. Does anyone have any suggestions of how I can get this model fixed up?
Ivy,
Removed some of the blend surfaces and overlaps
Re created few surfaces, extended current surfaces and trimmed, knit surfaces to create 2 solid bodies, later add blends
Hope the attached file works (it's not a 100% match to the existing model, still very close)
