4 Replies Latest reply on Sep 4, 2018 4:59 PM by Adam Doerr
    PDM API Help - Adding an error message to a custom program if drawing is not up to date
    Adam Doerr
      We have a simple program on a keyboard shortcut in Solidworks to print drawings at B size, but I'd like to add a warning/error message to the user if the drawing has the "File edited but not saved" pencil symbol and/or the "Referencing older version" exclamation symbol shown in the PDM pane. The pencil symbol shows up for the drawing, but the exclamation symbol is next to the part/assembly the drawing is linked/referenced to (also shown in the drawing's "Child Quick Info" column). Can anyone give me any suggestions on how to add this kind of functionality to my macro if it's even possible?
      Here's the current code for our program:
      Dim SWAPP As Object
      Dim PART As Object
      Dim pagesetup As Object
      Dim PRINTER1 As String
      Dim CPAPERSIZE1 As String
      Dim SHEET As Object
      Dim PAPERSZ As Variant
      Private Sub Form_Load()
      Set SWAPP = CreateObject("SldWorks.Application")
      Set PART = SWAPP.ActiveDoc
      Set pagesetup = PART.pagesetup
      Set SHEET = PART.GETCURRENTSHEET
      'PRINTER1 = SWAPP.ACTIVEPRINTER
      'CPAPERSIZE1 = PART.printsetup(0)
      'Text1.Text = PRINTER1
      'Text2.Text = CPAPERSIZE1
      PAPERSZ = SHEET.GETPROPERTIES
      'Text2.Text = PAPERSZ(0)
      PSIZE = PAPERSZ(0)
      If PSIZE = 0 Then
        PART.Printer = "\\SERVER\HP5N"
        PART.printsetup(0) = 1
      If PSIZE = 2 Then
        PART.printsetup(0) = 17
      If PSIZE = 3 Then
        PART.Printer = "\\SERVER\XES Synergix 8830"
        PART.printsetup(0) = 24
      If PSIZE = 4 Then
        'PART.printsetup(0) = 43
         PART.printsetup(0) = 25
      If PSIZE = 5 Then
        PART.printsetup(0) = 26
      pagesetup.Orientation = 2
      PART.printout2 1, 1, 1, 0, "", 1#, 0, ""
      End
