Hello, I'm trying to make a standard note for surface finish to drag from library.
I created the 'Note' annotation inserting the symbol
between brackets, spaces and comma getting the following note
Then I saved it in the library.
If I try to insert the note from library to a new drawing I get the following:
What am I doing wrong?
Mr. Schroeder's reply reminded me of another method: blocks.
Create the note as usual, save it as a block (renamed according) in the same folder as your Library notes are stored.
Then drag and drop the block onto your new drawing and it works.
But for some reason, the block version shrinks the surface finish symbols (highlighted), but when you explode the block (an exploded copy of the block is on the right), they're restored:
This is on a new drawing, not the original where I created the note and block.
Perhaps this is a workaround for you until you upgrade to SW2018 sp4 as Mr. Gupta mentioned.
Kevin
