When I click "max quality" render in the settings menu in
PV360 my render begins. If I close out of this render before it
finishes and select final render I get what appears to be a "max
quality" render as well. The difference being the "AA Samples" and
"Indirect Rays". By eye I have not been able to tell two of any
renders apart I have compared in this way. Is there really a
difference?
For example I rendered a part from the settings menu and ended up with AA Samples as 32 and Indirect Rays as 2048....with those settings I x'd out of the menu and did a "Final Render", where I finished with AA Samples as 8 and Indirect Rays as 128. I could see no difference in the two renders.
You may see difference when glass material is applied.
THis is off topic, but I LOVE your machine specs...
That is a kickin' machine....with all of the ROM you should be able to whip out some awesome images.
I tried a quad core for a while but it just didn't have the same kick or feel as the 64 engine. Sometimes old school is the new school.
