swRevisionTableMultipleSheetStyle does not update the exiting revision tables?
Question asked by Cuinn Herrick on Sep 2, 2018
It appears that swRevisionTableMultipleSheetStyle does not update the exiting revision tables. Changing from swRevisionTable_Independent to swRevisionTable_LinkedToSheet1 or swRevisionTable_SeeSheet1 via the API does not affect an exiting revision table. Although it does work when changed manually. This is a problem when trying to import drawings to PDM as they are blocked.
Dim swApp As Object
Dim swModel As Object
     Set swModel = swApp.ActiveDoc
     swModel.Extension.SetUserPreferenceInteger swUserPreferenceIntegerValue_e.swRevisionTableMultipleSheetStyle, 0,           swRevisionTableMultipleSheetStyle_e.swRevisionTable_LinkedToSheet1
Has anyone experienced this or have an API work around? I have tried rebuilding.
