You will have to make it its own body. If it is not a single
body, you can use the "Offset Surface" command to make a copy of
it, just set the offset distance to zero. Once you have the surface
copied, find the surface body in the Feature Manager Tree, in the
surfacing folder. Right click on it, and select "insert into new
part..." You can then export and save that surface.
