5 Replies Latest reply on Aug 31, 2018 4:16 PM by Scott Giffin
    Is a 3D lofted cut the correct method for this?
    Scott Giffin
      I'm trying to cut out a 1 degree angle leading between the rear relief and the extrusion land in this die insert. See attached files. I'm converting an existing AutoCAD file to Solidworks. I'm not sure what method to use to cut out the surface connecting the relief shape. One screen shot is the AutoCAD version and the other is where the 1 degree relief angle needs to go. I welcome all ideas! Thanks.
