Hello all
I am trying to fill the space between two bodies (corrugated plates). I wanna use this filled space as new body. What do you suggest?
I tried to draw a box around two plates to use combine (subtract), but when I select plates to be subtracted from the box it gives an error prompting to select another feature.
Thanks in advance.
Another way would be to throw a plane exactly between the two and sketch (I'm assuming) a square then 'extrude to next surface'.
