Balloon-change between item no. and props
Question asked by Niels Raahauge on Aug 30, 2018
Latest reply on Oct 17, 2018 by Peter Pankras
Hi
I use two kind of balloon.
1) item number with circle
2) Custom property SAPMaterrial without circle.
I want a macro to change between those to. Finding all the balloons  and change to SAPMaterial is working.
But I can't find out how to detect the Balloon type to get the chose, and ether how to get the item no. in the balloon.
I found:  swDetailingNoteTextItemNumber 2  but can't figure out how to use it.
Can somebody help, please. (I have comment out my best guess)
'open a drawing with balloons
'Macro to change all balloons to custom property: SAPMaterial
Dim swApp As Object
Dim Drw As Object
Dim View As Object
Dim Note As Object
Dim Bool As Boolean
'Dim swAnnotation As Annotation
'Dim BaloonType As Integer
Set Drw = swApp.ActiveDoc
If Not Drw Is Nothing Then
   If Drw.GetType = 3 Then            'Activedoc = Drawing?
      Set View = Drw.GetFirstView     '= drawing sheet
      Set View = View.GetNextView     '= first real view
      While Not View Is Nothing       'loop through views
         Set Note = View.GetFirstNote
         While Not Note Is Nothing    'loop through notes
            If Note.IsBomBalloon Then
'               swAnnotation = Note.GetAnnotation
'                BaloonType = swAnnotation.GetAttachedEntityTypes
'              If BaloonType = 2 Then 'item number
                    Bool = Note.SetBalloon(0, 0)  'no circle
                    Bool = Note.SetBomBalloonText(4, "$PRPMODEL:" & Chr(34) & "SAPMaterial" & Chr(34), 1, "") 'SetBallonToSAPMaterial
'               Else
'                   Bool = Note.SetBalloon(1, 0)  'circle
'                   Bool = Note.SetBomBalloonText(>>>itemnumber<<<<<
            Set Note = Note.GetNext
         Wend
      Wend
