On many of our parts (single body or multi-body) I cannot create a weldment feature (in order to enter cutlist properties).
When I press the Weldment button, it becomes greyed out and no weldment feature has been added to the feature tree.
Anyone know of a solution to this problem?
Are you familiar with Weldments? You do not have to hit the Weldment command button. You do have to use the Structural Member command or button. That's where the meaningful interaction takes place. I recommend that you already have a 3D Sketch to apply as members.
The Weldment Feature by itself does not show anything. It only defines that this component may contain a Structural Member. Structural Members create Bodies, which can show.
If unfamiliar, a Tutorial on weldments should make the process clear.
