I have a PCBA that was generated from CircuitWorks ( the PCBA is REV X10). It is the main assembly ( top of the feature tree ) of the file. I have added components to the assembly file such as heat-bars and fastening hardware to the file and generated exploded views and drawings for REV X10.
The PCBA has eveloved to REV X11 and I need to update the assembly file and the drawings. I would like to keep the exploded views and all of the drawing documentation.
Since REV X10 is the main assembly of the file, I cannot select and then replace the assembly.
Anyone know how to do this?
Kevin
Just to make sure I understand, REV X10 is the first component inserted into an Assembly. You wish to replace it with a similar file named REV X11. If that's true, why can't you just right-click on REV X10 in the tree and select "Replace Component" from the drop-down?
