i am making a simple blank strip in assembly, how can i take a sketch from a part, paste it to an assembly then cut that sketch out? when i try to orient the sketch entities correctly onto the assembly they move all around and out of alignment as well. thanks
Hi, it sounds like you might be converting the sketch onto a plane/face that is at a different orientation to the original, or it might still have relations to other bits of geometry/sketch entities.
If you select the desired sketch and copy it, then select the face/plane you want to paste it onto and paste. It should re-orientate itself on the new face/plane. If you use "convert entities" it won't if the planes are not parallel.
Could you upload any pictures/models that demonstrate the issue so we can see the exact situation you're encountering.
