I can't seem to make the edges Show up. I tried to use the Feature to Show the endges but i can't seem to click the lines
Nope, it's not working. The lines stay orange if after I've pressed the button. When I change the direction of the section view, it shows some of the lines. The object is symmetrical.
It's probably not behaving as expected because it's a section view. What type of model is this? If it's an Assembly you might try hiding components, or if it's a multiple body part you might try hiding bodies, instead of hiding edges. And that will probably require deleting this section view and inserting a new one.
It's an Assembly of a multiple body part. I tried reassembling the separate parts together, in thinking of duplicates in the same position. But that wasn't the case. I'll check again whether I have hidden a part during the chaos. There's actually no parts that I want to hide from the section view. I'll check it again on Monday, but under the consideration of the number of times, I repeated the action, it seems to not be the case. The orange lines represent a ball bearing that's used in the system and are hidden from normal view. Able to recognize that it is one is a critical feature.
Is there any other situation that would lead to such behaviour?
I'm not sure I understand the problem. If you click on a drawing view and select the "Hide/Show Edges" icon then any previously hidden edges should be highlighted in orange. You can click on individual lines to Show, or click on the "Rest All" button in the property manager to show all previously hidden edges in the view. Is this not working for you?
