A customer wants there to be a radius/fillet all the way around the inside of the part but it is not a consistent size. The bottom needs to be .03 R and the top needs to be a .120 R and the sides need to blend with the transition. Ive been messing around with Variable Size Radius/Fillet and I cannot for the life of me get it. Is it even possible?
It should be doable with variable fillet but you would need to calculate the blend %
Other option is to simply use loft cut after making the fillet sketches
