Long time lurker, first time posting on the forums. I have searched for a solution yet I am unable to figure this one out. I am unable to create a flat pattern from an imported part. I assume it might be because there is not a constant thickness throughout the whole part? Any suggestions on a work around? Thanks in advanced!
Select all the outside faces and Insert a 0.000" offset Surface and then thicken the surface and insert the bends, you'll need to hide the solid body from the import...
