I've been having trouble replacing the sheet format on multiple drawings using #Tasks's Replace Sheet Format tool.
The instructions tell me to populate the Find 1 field with * if I want to replace the sheet formats on all marked items with the template I specify on the Replace With 1 field, but, the result is the same (old) sheet format is loaded instead of the new one.
I also tried running it with the Reload Sheet Format with the same results.
Can someone, please, shed some light on this issue?
Thank you.
It didn't work form me, the format was referencing a path that didn't exist and the result was the same, the file loaded the old template.
I did just managed to acheive the desired results using your Macro: Batch Reload-Replace Drawing Sheet Format (sub folders as well) macro, it turns out I wasn't editing it correctly, so thank you!
