I have made several composer documents for assemblies. When I update some of these assemblies, the screws from the solidworks toolbox swap GUIDs in composer. For example, before I update, the GUID of one screw is "Psocket head cap screw_din11" but after I update the assembly the same screw's GUID becomes "Psocket head cap screw_din9". This means that its locations and properties in views are for the screw that was previously number 9. I can't find a reason that these screws' GUIDs should change. Note, this only happens with toolbox components which I assume is because they have the same name in solidworks. Since doing this I have noticed the "import instance names" option, but this doesn't help me with composer animations I have already done. Is there a way to direct composer to the correct parts or to simply change the GUIDs manually? I'm not keen on going back and re-animating everything every time I update.
Ben
Bit of a Necro-post, but I'm having the same issue.
The easiest solution for my team right now is to find out which screws are where in the updated composer file (easy enough based on the existing associative pathlines) and comb through every view resetting them using the "new" screws. Straightforward enough, but tedious and a large amount of work to have to complete EVERY time we update a file.
Ben, did you ever get an answer for this?
Any help would be appreciated.
