4 Replies Latest reply on Aug 22, 2018 12:31 PM by Peter McKnight
    How to swAssy.AddComponent5 at user specified location (more similar to drag and drop)?
    Peter McKnight
      I have created a custom explorer form to organize our company's parts categorically and have a macro to add the selected component to the active assembly.  However the best that I can currently do is to throw the part at the assembly origin which quite often is buried in the machine.  Is there any way to insert the component either via user location selection or at the current cursor location?  Thanks for the help.
        • Re: How to swAssy.AddComponent5 at user specified location (more similar to drag and drop)?
          Mr Omkar Deshpande
          I am not sure but swCommands_InsertComponents will help, i think
            Danniel Sims
            Peter,
            I ran into the same issue with a macro I made to use out of excel.  I used Getbox to get the exterior corner of the active assembly's bounding box.  Each time a part is added, the box increases, so the next added part is staggered outward from the center of the model.
            The following is straight code from a userform in Excel, but it should give you the basic idea.
            Dim swApp As Object
            Dim Part As Object
            Dim SelMgr As Object
            Dim boolstatus As Boolean
            Dim Feature As Object
            Dim ModelDoc As Object
            Dim Splitter, sldType
            Dim swModel As Object
            Dim swAssy As Object
            Dim vBox As Variant
            Dim X_max As Double
            Dim Y_max As Double
            Dim Z_max As Double
            Dim Pathname
            Splitter = Split(ufBOMSeek.lbSeek.Value, "\", , vbTextCompare)
            If UCase(Right(Splitter(UBound(Splitter)), 6)) = "SLDASM" Then
                sldType = 2
            Else
                sldType = 1
            Set swApp = CreateObject("SldWorks.Application.25")
            Set Part = swApp.ActiveDoc
            Set swModel = swApp.ActiveDoc
            Set swAssy = swModel
            Pathname = swModel.GetPathName
            On Error Resume Next
            vBox = swAssy.GetBox(0)
            X_max = vBox(0)
            Y_max = vBox(4)
            Z_max = vBox(5)
            If Not Part.GetType = 2 Then
                MsgBox "Active file is not an assembly."
                Exit Sub
            Else
                If Pathname = ufBOMSeek.lbSeek.Value Then
                    MsgBox "You cannot add an assembly to itself."
                    Exit Sub
            Set SelMgr = Part.SelectionManager
            Set ModelDoc = swApp.OpenDoc(ufBOMSeek.lbSeek.Value, sldType)
            Part.ClearSelection2 True
            'Part.AddComponent ufBOMSeek.lbSeek.value, X_max, Y_max, Z_max
            Part.AddComponent4 ufBOMSeek.lbSeek.Value, "", X_max, Y_max, Z_max
            swApp.Closedoc Splitter(UBound(Splitter))
            boolstatus = Part.EditRebuild3
            boolstatus = Part.SetUserPreferenceToggle(198, True)
            Part.ViewZoomtofit2
            Set Part = Nothing
            Set swApp = Nothing
            Hope it helps
