19 Replies Latest reply on Nov 28, 2018 1:27 AM by Marcus Olsson
    Nvidia Turing/RTX Questions
    Jeffrey Model
      I'm guessing this should be directed to Brian Hillner?
      The new Nvidia architecture sounds pretty awesome. To go along with Nvidia's announcements, I had a few questions regarding it support in future service packs:
      1. When can we expect support?
      2. Will both the GTX 20-series and the Quadro RTX be supported?
      3. Any early hints at the kind of performance boost we could expect on a single GPU setup?
      4. In systems with a mix of Turing and Pascal GPUs, what kind of support should we expect to see?
      --Jeff
        • Re: Nvidia Turing/RTX Questions
          Damir Galic
          In the video he mentioned that 2080 will have 10 times more raytraces per time interval than currently fastest 1080ti. That probably means 10 times faster rendering?
            Craig Girvan
            bI would assume that we wont really know the answer to most of these questions until after the cards are out.
            Howerver the new RTX cards appear to just be the next step up from the GTX 10xx range so I would not expect them to be 'certified' cards for Solidworks as the 1070/1080 etc were not supported. Although that doesn't mean they won't work in some capacity.
            I'm also always sceptical when companies say 5x or 10x faster at A or B task as this usually is only for 1 particular task. Hopefully there will be a good jump in performance though.
            Will be more interesting to see how the Quadro RTX cards perform.
                Jeffrey Model
                It's typical for companies like Dassault to be given access to new hardware (and its associated software/APIs) well in advance of its commercial release. That's how companies like Nvidia are able to give demos of third party software at launch.
                The GeForce 20 series won't be certified. I made the mistake of buying a certified card - once. The certified drivers and hardware offer literally zero benefit for Visualize, which doesn't make use of any of those restricted functions. Solidworks uses them for nothing other than the gimmicky RealView. Not exactly a big loss there.
                Frederick Law
                Current GPU scale better then CPU.  GPU use huge amount of cores to get the calculation done.  Increasing core amount and efficiency is very noticable with performance.  Calculating graphic is huge amount of array transformation, highly repetitive and predictable.  It will be pretty close to their claim.
                We may not see much improvement from CAD.  Unless CAD off load some calculation to GPU.  We are more limited by CPU.
                How much raytracing is done GPU in CAD?  I guess non currently.
                Video games had off load graphic and physics to GPU for a while.  CAD could benefit on rendering and simulation with GPU also.
                    Wojciech Paterski
                    We need A company to make breakthrough and make CPU based on the structure of GPU and how it works:)
                        Frederick Law
                        Not CPU breakthrough, OS.  We're burden down by the OS.  I think Windows still using 8 bits code that's why file path can only be 255 characters long.
                        PS4 is another RISC like nVidia GPU.  Intel is RISC emulating CISC.
                        Then our daily computer use is not as predictable and doesn't scale as well.
                        Jeffrey Model
                        If you set Visualize to GPU-only mode, nearly 100% of the computation is offloaded to the GPU. This is far and away the fastest mode for rendering. Similarly, if you use the GPU-enabled solvers in Dassault's various simulation packages, almost the entire job is run on the GPU. This has been the case for years.
                        Performance will be directly in line with Nvidia's claims. The only issue here is that Nvidia didn't claim performance for full render jobs, they just claimed performance for certain render tasks. A new GPU that draws the menu bar 2000x faster certainly performs that task much more quickly, but that is a very tiny part of a render job and thus the render time would remain unchanged.
                        And that's why I asked the question: How much improvement should we expect to see on render jobs given the huge improvement Nvidia is demonstrating on the various tasks?
                          Damir Galic
                          It's all about parallel processing. x86 architecture is linear processing.
                          I was really hoping that FPGA would eventually come into play and eventually replace x86...
                          But I still believe the future is in 3way transistors with 3d cubal chips. Performance on those could be squared.
                              Frederick Law
                              Problem is not all task can be run in parallel.  Some task require results from previous tasks and CPU need to wait.
                              Windows is based on old Intel CPU command set.  Intel tried to change it and failed.  So current Intel emulate old command set so Windows can run.
                              I don't know why MS and Intel still hold on to the old set.  Windows had been ported to other CPU already.  Program running in Windows don't care what hardware its running on.
                                  Damir Galic
                                  That's why I was talking about fpga.
                                  x86 has instructions such as A+B=C or A*B=C
                                  So if you would want to do (A+B)*C=D it would take 2 computer cycles.
                                  While with FPGA you can generate your own instruction that does (A+B)*C=D in 1 cycle. In fact you can do A*B*C*D/E+F+G+D=Z in 1 cycle. It's kind of parallel processing... but in reality is that multiple transistors get triggered at the same time in 1 cycle that produce that operation. There is ofcourse limitation to how deep the recursion goes but even that can be bypassed by supplying power somewhere in the middle of recursion tree.
                                  I think CUDA cores work like FPGA because you can supposedly program them how they operate.
                              Damir Galic
                              Also I think the future of computer graphics is graphics with no textures. Instead of reading bunch of textures from memory the cpu would generate them instead which would produce infinite detail. So if you would zoom in to texture that has 600x600 pixels it would start loosing detail, while on computer generated texture the detail would be generated as you zoom in. Basically generating any textures would be faster than reading from memory.
                              mark my words. it will happen.
                                Brian Hillner
                                Glad to see several people commenting on this forum thread!
                                NVIDIA's announcement is exciting for sure.
                                We are also waiting to understand their roadmap and if/when we can expect these new RTX cards to work with Iray (render engine within Visualize) or when we might be able to support the RTX raytracer as well.
                                Lots of moving pieces but hopefully we'll have some more definitive answers soon.
                                _Brian
                                    Jeffrey Model
                                    Thanks for the answer, Brian. Sounds like quite a bit more work is required for Turing than was required for Volta.
                                    In a similar vein, are you planning to update the GPU performance table to reflect performance with the AI denoiser?
                                    And, lastly, am I correct in assuming that Visualize will run just fine on Turing cards even if it hasn't been updated to take advantage of the new RT chip?
                                        Brian Hillner
                                        Yes - Visualize will run just fine, support and be accelerated by the new Turing cards (officially certified on the Quadro models: RTX8000, RTX6000, RTX5000). The date Visualize will support these new Turing chip generation cards has not yet been officially announced.
                                        I'm not sure of the exact performance gain comparing Pascal to the new Turing cards, but NVIDIA never disappoints in that area
                                        The SOLIDWORKS Certification team owns the Visualize GPU performance chart and will be making updates to it, also to reflect the Denoiser and Turing Quadro cards.
                                            Alex Ji
                                            My office recently received a few RTX 20 series cards and I did some simple testing.
                                                               960x540 fps     1920x1080 offline sec
                                            1080 Ti       25.91                76
                                            Titan Z        24.62                80
                                            2080           36.06                55
                                            2080 Ti       49.25                42
                                            Roughly, 1080Ti = Titan Z, 2080 is 50% gain over 2080, and 2080 Ti is 100% gain over 1080 Ti. I do not believe this performance gain is purely based on GPU horsepower. 2080 Ti should be about 25% faster than 1080 Ti in gaming.
                                            2080 offline.jpg2080 ti offline.jpg2080 ti viewport.jpg2080 viewport.jpgtitan z offline.jpgtitan z viewport.jpg
                                                Chris Rose
                                                How much is the RTX Quadrow entry level (5000 I think likely to be in comparsion to the RTX 2070, RTX 2080 both 8 gb, the Quadro p2000 or P4000 as trying to work out what to put into a custom build like this
                                                Case
                                                CORSAIR GRAPHITE SERIES™ 780T FULL TOWER CASE
                                                Processor (CPU)
                                                Intel® Core™ i9 10 Core Processor i9-7900X (3.3GHz) 13.75MB Cache
                                                FREE Call of Duty: Black Ops 4 & More w/ select Intel CPUs!
                                                Motherboard
                                                ASUS® WS X299 SAGE: USB 3.1, SATA 6 GB/s
                                                Memory (RAM)
                                                16GB Corsair VENGEANCE DDR4 2666MHz (4 x 4GB)
                                                Graphics Card
                                                PNY QUADRO P2000 - 5GB GDDR5, 1024 CUDA Cores - 4 x DP
                                                1st Hard Disk
                                                NOT REQUIRED
                                                1st M.2 SSD Drive
                                                1TB SAMSUNG 970 EVO M.2, PCIe NVMe (up to 3400MB/R, 2500MB/W)
                                                DVD/BLU-RAY Drive
                                                NOT REQUIRED
                                                Power Supply
                                                CORSAIR 550W TXm SERIES™ SEMI-MODULAR 80 PLUS® GOLD, ULTRA QUIET
                                                Power Cable
                                                1 x 1 Metre UK Power Cable (Kettle Lead)
                                                Processor Cooling
                                                INTEL SOCKET 2011/2066 STANDARD CPU COOLER
                                                Thermal Paste
                                                STANDARD THERMAL PASTE FOR SUFFICIENT COOLING
                                                Extra Case Fans
                                                2x 120mm Black Case Fan (configured to extract from rear/roof)
                                                Sound Card
                                                ONBOARD 8 CHANNEL (7.1) HIGH DEF AUDIO (AS STANDARD)
                                                Wireless/Wired Networking
                                                WIRELESS 802.11 AC1750 1,300Mbps/5GHz, 450Mbps/2.4GHz PCI-E CARD
                                                USB/Thunderbolt Options
                                                2 PORT (2 x TYPE A) USB 3.0 PCI-E CARD + STANDARD USB PORTS
                                                Operating System
                                                Genuine Windows 10 Home 64 Bit - inc. Single Licence [KUK-00001]
                                                Operating System Language
                                                United Kingdom - English Language
                                                Windows Recovery Media
                                                Windows 10 Multi-Language Recovery Image - Unlimited Downloads from Online Account
                                                Office Software
                                                FREE 30 Day Trial of Microsoft® Office® 365 (Operating System Required)
                                                Anti-Virus
                                                BullGuard™ Internet Security - 3 User, 1 Year
                                                Browser
                                                Microsoft® Edge (Windows 10 Only)
                                                Keyboard & Mouse
                                                PCS S300 USB MEDIA KEYBOARD
                                                Warranty
                                                3 Year Platinum Warranty (3 Year Collect & Return, 3 Year Parts, 3 Year labour)
                                                Delivery
                                                TIMED DELIVERY TO UK MAINLAND - MON-FRI, PRE-NOON
                                                Build Time
                                                Standard Build - Approximately 7 to 9 working days
                                                Is it better to keep the |I 9 or lower it to an 8 core I7 and up the Quadro to p4000 or a rtx 2070 gb
